I can set the PerfectPass Mph I want, throw the throttle down slowly until it beeps, then my boat keeps accelerating and doesn't hold the speed at which I set it at. I was going to do the servo motor troubleshoot but can't seem to find the servo motor. I have a 2005 22v Limited with the v8 GM Vortec 6.0L engine if that helps. Any ideas? Thanks!
Perfect Pass Question
Tigé Junkie
- May 2013
- 920
- Central MN
I do not see the servo motor in the picture. It is usually a silver box with a black knob on it. The black knob has a cable that attaches to it and the motor wraps the cable to hold the throttle in place."I think I am pretty smart for an idiot"
Tigé Junkie
- May 2013
- 920
- Central MN
Is the boat new to you? Have you successfully used PP on this boat in the past? If you answered Yes to the first and/or No to the second, then maybe there was an issue and the previous owner removed the servo motor. Hopefully this is not the case, just throwing darts at the board."I think I am pretty smart for an idiot"
