I have a 2007 22ve bought it new and this problem has got worse over the years. It first started you would hit a wake and the boat would beep and go into limp mode. Now every once and you hit the throttle and hear the transmission go in but there is no throttle at all. Turn the boat off and back on and it will start to work again. Some times u have to do that a couple of times before the throttle responce. Called the local dealer today and they said its most likely the controler behind the throttle. Any help would be nice. I know it is drive by wire
2007 Tige 22ve No throttle once and awhile
No I don't have a part number. Here is a link on an old thread of it also
http://www.tigeowners.com/forum/show...e-Issues/page2
Originally posted by amcdermott1978 View PostO i pulled off the handlle dont see any couple screws for a sensor hehind the handle..there is a bei sensor towards the top of the handle...my shifter has a big square box behind it
This isn't the one but similar to what your looking for: Guess they call it a TPS also but basically has resistor type setup that sends throttle signal on those boats.
https://www.google.com/search?q=thro...Nl9h0aGGjjM%3ALast edited by JLG; 04-18-2016, 08:28 PM.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
The handle has (at least) two functions: Engage the transmission (which is done mechanically via a cable) and request engine power (which is done electrically via a wiring harness). All you really have to do is find the wires that go to the behind-the-wall portion of your handle assembly, and you'll find the TPS.
If your handle also has the TAPS switch, you'll have (probably) three more wires in that neighborhood. It should be easy to tell them apart.
If you take photos and post them, we might be able to help!
Originally posted by amcdermott1978 View PostI found the the tps sensor it is a bei...just want to know if you can buy them only
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by chrissnow View PostFrom memory mouser sell them
I strongly urge you to go over the spec sheet very carefully, confirming that you are ordering the correct part. Check mounting dimensions, mounting hole styles, etc. Then order with confidence from Mouser, they're a great outfit, I have a box of stuff from them sitting three feet from me right this very minute. Should be a drop-in replacement.Last edited by IDBoating; 04-19-2016, 04:58 PM.
