I'm looking at purchasing a 2011 Tige RZ2. The boat has Tige Touch, and speed control via paddlewheel. Does anyone know if this can be converted to GPS, and incorporated into the Tige Touch system?
2011 Tige RZ2 Speed Control
http://www.nauticlaugic.com/nl4.html replaces paddle wheel with gps signal. I think it works with anything that uses a paddle wheel. I would recommend you Give them a call.
Edit: website lists 2007-2014 tige so it should work
Sent from my iPhone using TapatalkMods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
