PAR-MAX 2+ – 2.8 GPM (10.6 LPM).
    Hello, I had a question as to what this pump is for in the back right corner behind the battery box on left side of boat. it has a hose running into the pump and a hose running out of the pump.
    I have a 08 tige 20i (like to barefoot, slalom and surf.) I have ballast in back and two tanks up front.
    I have enclosed a bad pic. Any one know what this pump would be for? I have shower and heater but does not connect to these items.
    It does not look anything like my intake pumps for ballast. I have attached a bad pic.
    Follow the hoses.
      what type of hose is connected to it? Clear, Black, Steel Re-enforced?
        Looks like a shower pump.
          Shower for sure. Head houses a pressure sensor. when the nozzle is squeezed, the sensor senses and the pump comes on.
            Black Hoses conected to the pump. I in and I out
            Yes probably shower pump.
            I took out batteries so will confirm in Spring once I put back in and turn shower on.
            Thanx
            Bill
              Might want to make sure all the water is out also.
