2006 24VE, Marine Power. Starts fine first time for the day. Restarts fine after it is warmed up. Won't restart at all if turned off while still cold. Starter fluid did not help. Just cranks and cranks until the next day when it starts right up. Any ideas?
Won't restart after turning off when cold
My input on vapor lock was wrong, I misread your post.... sorry.
If it starts, then you shut it off a minute and it won't restart it's likely a fuel issue, either too much or too little. I still don't have the exact scenario in mind of what is happening.
Does your coolant gauge read correctly all the time (ie ambient temp on first start then gradually warming up to 150-180)?
