That does make sense, regardless, I'm just happy we got it off!! 9 years provides a really tight seat!
Major vibration
Originally posted by jleger98
yeah, gliding into the dock or the ramp or something, but that would not explain how/why the speedo pickup was busted.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by baroda5
Apparently so, I didn't realize props were so vulnerable. I'm just amazed they can fix that!! Do they heat it and press it back in a die?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert
I'm telling you, I just brushed something gliding onto my trailer...I had it lined up perfectly and everything. They fix it with a hammer and then smooth it out on a grinder for simple things like yours. I'm not sure what they do when they are really mangled.
Did the Marina keep your boat on a lift? Seems like all this damage could have been caused by an ill fitting lift."I want to know God's thoughts, the rest are just details"
When they are really mangled, they sell you a new one
When I first had my first boat, I went to back off from the dock and hit a pile of rocks that (obviously) had no idea was there.
When I brought the prop into the shop, the guy just chuckled at me as he was getting his catalogue out. Needless to say, I've been much more careful. The old one is on the wall in my garage as a reminder.Reality is only an illusion that occurs due to a lack of alcohol.
Originally posted by Tequilasun
I think they take blank blades and weld them on, then shape them.
HELP !! NEED STRUT ASAP !!!
I finally found the sourse of my vibration. My strut is bent to the right about and inch. The prop still turns by hand but the whole thing is out of line.
I need a strut next day air..... I leave on vacation on Saturday... I will pull an all nighter to replace if I get one on time....
Help !!
Call 717-856-7609
Scott
Bummer, dude! If your strut is bent, then your shaft probably is, too. I think you can straighten the fin with a rubber mallet. I'd call a Tige dealer to see if they have the part you need or can get it for you.
You'll need these aligned fairly precisely and I'm not sure what types of tools you'll need, but it may be more than you're willing to do.
I'd have a qualified mechanic look at this.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Strut replacement advice
There is a big divit in the strut where it hit the rock. The shaft looks ok.
The fine guys at Tige Watersports in Ca gave me the low down on replacing the strut. Sounds like 2 guys, one in the boat, one under, and a #3 phillips on a ratchet. Take out 6 bolts, take off the prop, slide off the strut, reverse....
They recomended removing one o fthe muffler pipes, and warned me that 2 of the 6 nuts would be very hard to see.
I read the thread about the silicon holding the thing on and needing to swack it with a rubber mallet.
So.. any other advice out there ??
make sure u clean the bottom surface real well and dont forget the 5200 sealant. its a 3m product. i am sure you have seen it, just dont forget to use it. your other advice seems right on the money.i would also agree that if your strut is bent as you describe that the shaft is also damaged. you really should have it checked. good luck.Last edited by kko; 07-18-2006, 10:51 PM.
