So pulling out what little hair I have left. Started having issues with starting our boat. First run out after putting the FAE on, the boat took forever to start in the water. Out of the water, not a problem, barely cranks over and starts right up. In the water, you have to crank, FOREVER and it might sputter a couple of times before it will actually start. I find I have to give it a bit of gas to get it to start. I replaced the cap, rotor, spark plugs and wires and took it out again today, same thing. Ended up keeping it running all day so I didn't have to deal with it. Kind of embarrassing when you have a boat full of people. Beginning of the season (may) I replaced the fuel/water separator filter.
At this point I am completely lost. Could the FAE actually be causing this? I had one person tell me that they had a similar issue with a same model year Tige. FAE off, they had no problems, FAE on, it took extra cranking to start it up. I don't mind some extra cranking but to the point that I'm afraid of it killing the battery, that is too much.
To me it seems to be starving for fuel. When you turn the key on, you can hear the fuel pump come on and after you finally get it started, she runs like a champ, no heating issues, nothing.
Completely lost......
