I was doing my basic routine of cleaning and generally messing around in my boat today and I just happened to glance at the fuel pump. I noticed that the coil wrapped around it is loose and hanging down further than it used to. So, of course I start to investigate. I am not sure if this is a problem. It looks like it was jb welded in place from the factory and that weld has broken. I really have no idea how long it has beenn like this. I can easily wiggle it up and down a full half inch.
Anyone ever run into this? If so, what did you do to fix it?tmp_20150618_1825281248158992.jpgtmp_20150618_182551247315472.jpg
