RZ2 ignition-Key won't turn!
    2012 rZ2 ignition has been a issue always had to jiggle the key and reach from behind to get it to turn over to start position. Now it will not turn either dierection to start or acc. Tried the spare key nothing. No problems with it once you can get the key to actually turn, starts right up. Key literally will not move once in the ignition.
    Ps it's beautiful out and I'm stuck at the dock if there is no quick fix can it be hot weird easily. Thanks for any help!
    Yes you can hot wire it if you know what you are doing. Actually it is easy. Or you could get a new one at the auto parts store and install it until you can get a marine model.
    Wake Up or Stay On Shore!
