I have a Merc 350 MAG MPI that has a soft alarm. The boat runs great, I had the codes checked and it was alarming on the IAC. I replaced the IAC twice this past two weeks with brand new ones. Still alarming so I took it back and had the codes checked. Now they say it is throuhging random errors IAC being one of them. If I turn the key on with out starting the engine I still get the codes. I have checked all the connections I can find to sensors. Does anyone have any ideas on how to trouble shoot this?
Soft Alarm issue
What kind of alarm? Soft alarm is not a technical term so if you could describe it that would be great. Either 2 beeps every minute or one steady beep. Is power limited after the alarm? Does the engine have issues running? Worst case scenario is a new ECM but give as much detail as possible.Fixing everyone elses boat just so I can use mine...
