Prop shaft size
    Prop shaft size
    Just bought me a 96 2002 fslm comp, and it didn't have a prop. Is the shaft 1 1/8
    Or 1? I've Been told both and don't have a way of knowing as I am new to this. I've read it's a lh prop. Would it be a 3 blade or 4 blade or does it matter ? Thanks in advance
    I am not sure the answer to your question, but I have heard that calling ACME props may be a good resource. They have a vast knowledge of many boats and may be able to lead you in the right direction. Good luck!
      If its a DD, then for sure you need to go with a 3 blade. Yes its a LH rotation. Dont think ive seen anything but a 1-1/8" shaft on a Tige.
        I've talked to several different places and they all don't seem to know either . So a 3 blade will
        Def be best for me I'm guessing
          Welcome to the site and congratulations on your new ski machine. I would call ACME Propelers and give them your information. They will help you set up the right prop for your needs. You will be at a slight disadvantage since you don't have any feedback to give them on your non-existing prop. Regardless, it's well worth your time to call. 1-888-661-ACME
          http://www.acmemarine.com
          Post up a pic when you get a chance.
