97 2150 taps questions
    I believe they self bleed. I would guess if your ram was fully extended and full of air you would struggle though.
    You could run the pump and give it a gentle push then a few cycles to purge the air.
    Does the plate move freely with the actuator detached?
    Could just be that the actuator is seizing up and needs a rebuild or replacement.
      I don't think the Rams are fully extending and I haven't really messed with much just got it in hooked up made sure it moved the plate and put the boat up for the night as it was late but I'll try that this weekend when I'm messing with it
