heater core
    heater core
    heater core is not working and im getting a leak at the core underneath the steering wheel. looking to just disconnect the hoses at the block and plug them with a bolt. any ideas on what size bolts it would take to plug them holes with?
    or any kind of other option to bypass the heater
      Just connect them together with a short piece of hose
        think that will be ok for the water to continue to cycle through there, not going to hurt anything?
          It will be fine. The prior owner of my boat had bypassed the heater by connecting both hoses to a metal fitting. I just got a new heater core & hooked it up for the new season. Either way, the water just circulates in one hose & out the other.
            Awesome, any idea what size hoses these are? im sure in the AM i can get down there and check it out. Was wondering if anyone knew off the top of there head
              Should be 5/8" heater hose.
