ok my boat has something going on with it. its a 2000 tige 22i with 300hrs. the boat pulls hard with no issues but while running on or off plane it will slip when I turn hard. it don't do it everytime but it does it enough to be worried. it does not do it while running surf speed but it will do it while turning at wakeboarding speed 20-22mph. its almost like the prop is blowing out/slipping.
seems like the transmission or prop is sliping HELP!!
Here's an older link and sounds similar to what you explain is happening with your boat:
http://www.tigeowners.com/forum/show...ow-speed/page2
Not sure if aerating as boatwakes said, is the same as cavitation but seems similar.
Yep, same problem with my boat last year. Scared the crap out of me thought I fried the clutch plates. Running the acme 911, haven't heard a peep out of the transmission/cavitation since. BoatWakes as always, is spot on, its cavitation and usually only turning to the right will it happen, turn hard and fast as you want to the left and its good to go, but a quarter turn to the right with any decent amount of power input and it will have cavitation. I called velvet drive too, before I knew what was going on and they said the same thing.My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
Just Re-Prop the boat, mine would do it at random regardless of weight. Some days I could put surf weight in it and no issues. Other times I couldn't even get the boat to plane out before it starting slipping.My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
