Originally posted by dom w. forte
View Post
Where to start: non-functioning speedometer 2006 24Ve
Tigé Expert
- Oct 2014
- 1252
- Great Faces, Great Places--South Dakota!
- Used to have gangsta lean 24Ve; then GSA F24 Tomcat, now a 2016 Supra SE450. Onward we roll!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
I presume this is an AirMar triducer, perhaps from their DST800 series. If so, the green wire is, indeed, the speed signal from the paddlewheel (comes from a Hall effect sensor that the paddlewheel rotates near). The Hall effect sensor gets its ground reference from that bare wire that is wrapped around the brown one, and it gets its power from the red wire that is spliced to the heavier purple wire.
I would start by confirming that you see +12VDC between the small red wire and the bare shield wire. That would mean the triducer is getting power. Then, lacking a frequency counter or an oscilloscope, I would measure the voltage between the green wire and the bare shield wire. As the paddlewheel is SLOWLY rotated, you should see voltage, then none, then voltage, then none. The normal signal output on the green wire is a pulse train generated by the paddlewheel magnet passing by the Hall effect sensor. At speed, you get a pulse train - but with slow rotation I *believe* you will see switching voltages as the Hall effect sensor sees the magnetic field, then no field, etc. Caveat: I may be wrong about this; depending upon how the circuitry is set up, it may be that turning it manually isn't enough to cause an output change. That's why I recommended the air compressor earlier, but then a voltmeter won't be able to reliably indicate a pulse train.
Run this experiment and report back.
Tigé Expert
- Oct 2014
- 1252
Originally posted by WABoating View PostI presume this is an AirMar triducer, perhaps from their DST800 series. If so, the green wire is, indeed, the speed signal from the paddlewheel (comes from a Hall effect sensor that the paddlewheel rotates near). The Hall effect sensor gets its ground reference from that bare wire that is wrapped around the brown one, and it gets its power from the red wire that is spliced to the heavier purple wire.
Run this experiment and report back.Time flies like an arrow; fruit flies like bananas!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Remember to have him rotate it slowly. I haven't checked but it probably puts out two pulses per rotation. If he spins it too fast you might miss the voltage changes on a digital meter. Do something like "Rotate until one of the little paddles is pointing down. OK, now rotate it 90 degrees until the very next one is pointing down. OK, repeat. OK, repeat."
Tigé Expert
- Oct 2014
- 1252
Perfect. Thank you, even he I think can hang with me on this one.
Originally posted by WABoating View PostRemember to have him rotate it slowly. I haven't checked but it probably puts out two pulses per rotation. If he spins it too fast you might miss the voltage changes on a digital meter. Do something like "Rotate until one of the little paddles is pointing down. OK, now rotate it 90 degrees until the very next one is pointing down. OK, repeat. OK, repeat."Time flies like an arrow; fruit flies like bananas!
Another indication is that if it's a 2 wire sensor (usually twisted) , it has to be a Hall Effect sensor as described above. For it to be a true position sensor where voltage will be present as you move & hold it, it needs 3 wires, V+, ground and signal.
FYI, you should be able to put a DVM on A/C, hook the leads up to the twisted pair, spin the wheel and see voltage if all is working.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by ericinmich View PostI don't know the specifics of the paddle wheel sensor but based on my knowledge of automotive sensors, I think that the wheel needs to be moving for it to put out any signal. It's likely a Hall Effect sensor, basically a magnet and winding with 2 wires coming out.
As for the AC range on a DMM, that's why I recommended that they use an air compressor to spin it at a reasonable velocity. We don't know the input characteristics of his DMM so we don't know how much averaging he'll get applied to that pulse train. If he doesn't spin it fast enough the signal may be hard to distinguish from noise.
Tigé Expert
- Oct 2014
- 1252
I need to sign up for am automotive and mechanical electricity course at the local community college--you guys amaze me. The multimeter I own does me very little good as my electrical knowledge is lacking. I feel inadequate! I will nevertheless check this. Football ran too late tonight and my son is in bed. We will try tomorrow!Time flies like an arrow; fruit flies like bananas!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Boat ownership spans a wide range of careers and professions. The particular problem you're addressing in this thread is attracting the attention of people whose skills are in this area. Others will chime in on other subjects. The cool part is that almost everyone here is willing to help, share their knowledge, and do it with a smile. It's a great community.
Tigé Expert
- Oct 2014
- 1252
Originally posted by dom w. forte View PostHave you gone to the back of the speedo guage and back tracked the green wire to make sure you are on the right trail because I have not ever seen any splices splices on the green wire.
1. One half of the splice goes to the speedometer, and matches according to the schematic I obtained from Faria.
2. The other half of the splice appears to go "south" in the harness and ends up in the same loom as the SpeedSet wiring. I can only assume my SpeedSet panel also uses the raw Triducer signal to capture and hold speed?
For some odd reason, the gauge of the wire changes dramatically after this splice. It looks really odd and cobbled up, but looks like it was factory installed. So darned odd.Time flies like an arrow; fruit flies like bananas!
Tigé Expert
- Oct 2014
- 1252
Also, just to confirm, the ONLY way to test triducer signal is to use a multimeter on the green wire to see if I am getting a signal?
In other words, if I manually (or with a hose) spin the paddlewheel with key on, I WILL NOT see the speedometer climb as if the boat is underway?
If the above sentence is true, why does that not work? As you can tell, I just want to see that needle climb.
Note: the prior owner AND a third party mechanic both told me it worked before purchase. I then carefully examined a running video from them and could barely notice that it was NOT functioning in the video. Gee thanks, guys! Shame on me for believing them.Time flies like an arrow; fruit flies like bananas!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by dakota4ce View PostAlso, just to confirm, the ONLY way to test triducer signal is to use a multimeter on the green wire to see if I am getting a signal? In other words, if I manually (or with a hose) spin the paddlewheel with key on, I WILL NOT see the speedometer climb as if the boat is underway?
As mentioned earlier, be sure to confirm that the unit is getting +12VDC too. Then I'd worry about the output signal. Keep in mind that the speedo itself may be the culprit, which is why I suggested examining the SIGNAL at the green wire. Lack of gauge movement does not automatically mean the triducer is the problem.
Tigé Expert
- Oct 2014
- 1252
Okay, roger all of that. I will check power and also keep in mind the gauge may be the problem. Thank you!
Originally posted by WABoating View PostNo, spinning it with a hose should work. I worry that doing it with a finger may not work reliably, since the speed will be all over the place. But a hose should do it.
As mentioned earlier, be sure to confirm that the unit is getting +12VDC too. Then I'd worry about the output signal. Keep in mind that the speedo itself may be the culprit, which is why I suggested examining the SIGNAL at the green wire. Lack of gauge movement does not automatically mean the triducer is the problem.Time flies like an arrow; fruit flies like bananas!
Tigé Expert
- Oct 2014
- 1252
Does this seem feasible to you all and does it possibly suggest gauge failure? It seems to point to that.Time flies like an arrow; fruit flies like bananas!
