Throttle Hang??? HELP
    Originally posted by bneub
    My ground bar is under my right rear seat, but I could try that also. Maybe the main wire to the ground bar is damaged somewhere. What guage should it be?
    8 or 10 AWG
      I double checked the ground bar screws this morning. Two terminals were just slightly loose. I tightened them and will see what happens this weekend. Thanks!
        bneub,
        Anything new on your boat? I'm back to the 'drawing board' with mine, it acted-up this weekend.
          Originally posted by chpthril
          bneub,
          Does yours still act up with and without accuset turned on? I have been scared to try my taps with someone riding. I hope to work with it some this weekend.
          I talked with the guys at pp yesterday and hope to dial in my settings to get a better pull. I am currently fluctuating over 2 mph when pulling someone.
            It did it when I hit the set button on the accuset
              Contact your dealers and request them to contact tige , there is one additional modification they can do that I beleave will fix your problems. Dom@ Fortes Inboard Connection.
                Dom,
                Can you give me a hint as to what it might be, so I can point my dealer in the right direction!
                Thanks for the info.
                  Me to Dom, my dealer is stumped right now. I would love to give them an idea. I live 2.5 hrs away from my dealer, so I would do it myself if it is possible.
                    Call me at 1888 517 3178 ask for Dom Fortes Inboard Connection.
                      Thanks Dom, I will call you soon, been 'wide open' here lately.
