Replace One of my 3 steg fins under boat or not?
    I have a 2002 Tige 2300ltd and use it to tube and wakeboard and ski with my boys.
    I hit a huge log and ripped off one of my steg fins under the boat, the other two are fine.
    Should I add / replace the front steg or simply patch the 4our bolt holes on fiberglass boat bottom and move on ???
    Luckily my bilg pump worked well enough to get me back with out boat sinking.
    Sorry to hear about your bad luck. I saw a boat on our lake last weekend that did about the same only bent rudder and most likely shaft also. Do you have pics you can post?
      i would replace the fin. I would assume tracking would be degraded if you go with two. but curious if you dont how it tracks.
      2011 Tigé RZ4
      www.re-viveupholstery.com
