I'm new to the forum and new to the Tige Family. I just purchased a new to me 2006 Tige 24VE 2 weeks ago. I have had the boat out about four times now. The first two times I pulled the drain plug there wasn't much water that drained out. The third time I took the boat out I installed a 1100 lb Ronix ballast bag in the left rear corner. We got done boating for the day(roughly 6 hrs on the lake) and I went to drain the bag and noticed both of my rear lockers were wet. Water had filled the bilge area and begun to come up into the lockers. After I pulled the boat out the bilge drained for a long time, 30 minutes or so. I called the local Tige dealership and they told me to check the packing around the drive shaft(not sure how to do this), and my platform brackets. I didn't notice anything irregular to me, but then again this is my first boat and I am not sure what I am looking for.
So yesterday I took the boat out again. I was suspicious of the ballast bag since that was the one variable that had changed since the first 2 times out. I filled the bag about 80% and kept an eye on everything. Carpet in the locker completely dry. However after about an hour of surfing there was water in the bilge up above the bottom of the oil pan. So I drained the ballast and the bilge and ran the boat for another 1.5 hours. I looked at the engine itself periodically and could not see water coming out anywhere. The water in the bilge did still come up with out the ballast just not near as much nor as quickly. The boat seems to run fine, I haven't noticed anything different with the way it has performed. The Tige dealership can't get me in for two weeks. Do any of you have any ideas what this might be or how I can narrow it down? I really want to keep using the boat but don't want to risk ruining something expensive? Thanks in advance for any input!
