WARNING BEEP NOT SURE WHAT IT IS 05/06 TIGE 22VE
    I have 05/06 tige 22ve and my boat started acting up we went out all morning with no problems then went out in the aftrernoon everything started fine within a couple of minutes my wife crashed we hit someone wake and the water was pretty rough when i put the boat in neutral an alarm goes off similar to the depth alarm but wouldnt go off i checked oil and it was fine temp gauge showed fine and had only been out about 10 mins battery gauage was a little low after missing with it for a few minutes and having it turned off i got it to go and it drove and acted just fine but my wife finally talked me into letting off gas and stopping so she could ski to the dock upon doing so i had same reuslts i turned off and finally got it to go sometimes in order to get the boat to start i have to move gas lever slightly forward to get it to realize it is in neatural. any ideas or suggestions thanks bryan
    My local Tige dealer said it is probably the potentiometer
