Noticed on this last trip out that the blower and bilge pump will not turn on. The TT shows the blower activated when starting, but it is not running before or after the engine is turned on. The bilge pump will simply not activate.
We recently had a couple REV 10's and an amp installed and the problem may have started at that time, not sure.
Where is the fuse box that has the fuses for these two systems and what else can I check?
thanks
thanks
