2002 tige 20v engine upgrades or tramny upgraded
    So I have a 2002 tige 20v and it's always been great but I feel it's starting to slow down on power. I'm running a 3 blade 9 pitch prop. Looking to get low end torque so what are some good upgrades to do? I change filters and fluids regularly did spark plugs last year. Also did new distributor. What about intake? I've thought about seeing from switching from 1:1 to 1.5:1. Just wanting some input.
    What diameter is that 3 blade 9" pitch? The only only way to "fix" a tired motor is to rebuild it. I would start with a compression check to get an idea on its soundness.
      I've done a compression check and it was all within spec. The prop I believe is 13" 3 blade it's the one came recommended for the most hull shot. Was just lookin at doing a few upgrades didn't know if anyone knew any good ones
