So, the maiden voyage this year did not go well at all. No power under load and a terrible miss - including audible knock at one point. Started fine and idled though. Also revved quickly and all the way to the high RPM band in neutral. I am thinking bad gas, but the overall system likely needs to be totally cleaned and may also need to replace pump(s). Who knows... my plan is to start small and trouble shoot toward the bigger and more expensive stuff.
I also have leaks coming from the raw water pump housing and from the hose aft the transmission screen (from the water pump).
I could really use part numbers / a manual to order the stuff I need, but am not sure what manual to pick up. Here is one I found:
http://www.amazon.com/Mercruiser-Man...ruiser+manuals
Can someone please let me know if this would be the correct manual?
Even better would be to be able to find parts directly. I'd like to use this site, but am not sure where to find the serial number of the engine. Does anyone know where I can find it?
http://www.marineengine.com/parts/me...FewDOgodCRIAgg
Thanks in advance!!
My engine is an '04 mercruiser 5.7 335HP engine.
Thanks in advance!!
