Could anyone please help. I have scoured all other post related to taps issues however have not come across the same issue as I am having.
I have a 2011 rz2 and am having problems with the taps2 gauge not working (the tab itself works fine however neither the analogue or touch screen gauge indicates what position the tab is in).
I have checked wires to/from the motor/tab to the gauges/wiring loom and all test ok. I have found when I disconnect the medallion trim tab module under the dash the gauges move to position 8. If I plug the medallion trim tab module back in the gauges move to position 1 (and with the module connected or unplugged the taps plate moves however the gauge does not). Does anyone know where I could get a replacement 'medallion trim tab module' or if there is something else I could try?
Cheers.
Cheers.
