I had lost a lot of engine power suddenly.
Looked at engine and water was spraying around from the aft side of what looks like the water return.
Long grey painted cylinder on right side of engine as I face rear.
Is this a loose hose or fitting?
I pulled onto boat ramp and drained boat again and dry the engine fired up and ran perfectly.
My bilge pump does not work at all so is it picking up water from bilge and throwing it around?
I never let that much water in the boat and pull out and drained after each couple of hours.
Drained a lot of water out which is not usual for my boat. It’s usually bone dry when I pull the plug.
Is a loose hose or fitting causing so much water to be brought into the boat?
