Well as the title says, after surfing last night with my girlfriend I was not paying attention like a dumbass and missed a buoy. Before I realized where I was, I smacked a rock pretty good. I was able to idle it boat into deeper waters and swim underneath to inspect. Everything will still intact so I decided to idle back to the house and get the boat on the lift to inspect further. When I was driving back I realized that my steering was very tight - I assumed I damaged the rudder as well.
Upon getting the boat on the lift and looking things over, I saw 3 of the 4 fins on my prop are pretty dinged up. This should not be an issue as my buddy across the bay has pulled his prop off before and is going to give me a hand so I can have that repaired. What I am worried about is the rudder. I attached a picture of where the rudder shaft enters the boat. It looks like the rudder hit the rock as well and bent back so now it's pressed up against the surrounding metal. The rudder itself does not appear to be damaged.
So at this point in the season I think I am going to try and take care of this myself. Unfortunately I do not own a trailer as the boat sits on the lift all season so I am going to attempt to do this while on the lift. Is the rudder a two piece assembly? It appears that the brass rudder is attached to a stainless shaft somehow. Can I just replace this stainless shaft? Is this a Tige specific part? Any insight at this point would be greatly appreciated - I am pretty sick over this and need a little guidance as what to do, thanks in advance!
