2008 Tige 24ve Taps struck by lightning
    Hi everyone,
    I've done a bit of searching around the forums and have not came up with a good solution as to how to fix my taps.
    A few weeks ago my boat got struck by lightning, crazy I know. After the lightning strike my head unit, speedometer, and my taps got fried. Everything got fixed by a local dealership, except the Taps. Currently the TAPS is stuck on 1 and the plate wont move at all. When I hit the taps switch the only thing that happens is a loud click comes through my speakers.
    My boat is a 2008 Tige 24ve
    Any advice/help would be much appreciated.
    Thanks
    There is a special relay that most like/y got fried. I don't know about your year boat, but my TAPS relay is clear plastic. Mine fried but I just left it and 1 since its the best wake with the weight we use.
      You will need a new brain. Mine did the same.
      2016 Tige Z3, 2014 Tige Z3
        So I found out the plate sounds like it wants to move down. It just won't move up, you thinking it still needs a whole new module?
          Sounds like it needs a relay module. I think you can order one directly from bennet trim tabs but I can't be 100% sure on that.
            Just to post an update for everyone:
            I went out on tuesday and hot wired the pump for the taps, I was able to fully adjust it manually so I planted it in surf mode so that we could at least ride.
            Upon reconnecting everything, the gauge works and moving the plate down works. I just cannot move it up.
            I'm going to call bennett today and see what they suggest. I'll keep you updated.
            Here is a pic from tuesday, sorry that it's more truck than boat.
              That is a sweet looking rig you have there! See you on the lake
