I have a 2012 R20 with 343hp PCM. It keeps throwing a code about the TPS( Throttle Position Sensor) Dealer keeps resetting the error but every time I engage the throttle the error appears! Dealer replaced sensor once already so it must be something else! Any suggestions?
Engine code
I have an 06 24Ve with the same code/problem. I believe it is a code 81. I pulled my PPS (pedal position sensor) from the throttle lever mechanism last night. I am having trouble finding that part online. I have read that that particular code could be a variety of problems; oil pressure, engine temp, fuel pressure, etc...at least in 06. I would really like to hear any solutions as well!
Originally posted by Parker View PostI have a 2012 R20 with 343hp PCM. It keeps throwing a code about the TPS( Throttle Position Sensor) Dealer keeps resetting the error but every time I engage the throttle the error appears! Dealer replaced sensor once already so it must be something else! Any suggestions?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
