Throttle handle set screw replacement on my 2001 Tige 2100 LSV
    My throttle handle was a bit wobbly the other day. Turns out the set screw is missing. Anyone know of a replacement or size of the screw?
    Thanks,
    Brian
    Never mind. I found a post on here by someone named Dingleberry and he got it right. There is no set screw. Just used a 2.5mm Allen Wrench and tightened it up.
