Okay, I have been trying to find a leak somewhere. I have tore the engine compartment apart so that I could find every hose clamp and fitting to check to make sure each one is tight. I have a 2000 2300V. Just sitting in the water not running I think (can't tell for sure) it takes on a small amount. But when we are running (surfing, tubing, knee boarding) it takes on a good amount of water. As long as we keep up on the bilge pump, no problem, but we are wanting to keep the boat at a dock for the summer and can't afford to have it sink if it sits for too long. My only thought is it may be one of the heater lines going to the cabin heater might have a split? The heater has not worked since we bought the boat so I thought of disconnecting the lines from the motor. Anyone else ever have any problems with this series of Tige?
Thanks!
Thanks!
