For some strange reason lately, every once in a while when starting my boat the idle will be significantly higher than it should be. Usually it is around 600rpm but I have seen it sit anywhere from 900-1000rpm after start up as of late. It will do it when it is cold and warm, so temperature does not seem to be the issue. I can shut the boat off for a few seconds, then start it again and most of the time it goes away... Yesterday when I started it cold, it idled around 1100rpm and started to slowly rise which puzzled me. I shut the boat off and started it back up 30 seconds later and it was good to go for the night. Any ideas on things to check/replace/tighten up?
Thanks in advance
Thanks in advance
