my boat turns very easily. When I let go of the steering wheel it does turn hard right. Every inboard I have been in is this way.
fslm questions... tracking? top speed?
It's definitely differant than an I/O. Mine is smooth as silk one way and needs a little muscle the other. I guess this is in part due to no power steering and in one direction you push the rudder, the other you are pulling the rudder. and prop rotation.
Mine will track straight if you let go of the wheel.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by SC FLSM View PostAlso, I thought inboards were supposed to steer a little easier. Should you have to fight the wheel at all?
One more.... I know this is not a speed boat, but does 40mph sound right for a top speed? It is fine with me, but I am just curious.
Thanks to anyone who can help.
If your steering wheel is hard to turn you probably need to change your steering cables. This is a fairly easy repair, you can do it yourslef. Heres a link to a thread about it....
http://www.tigeowners.com/forum/show...teering+cables
Over time if it gets harder to turn, its definately the cables. I had the same problem on my boat.Common Sense is not so Common
