2008 20V Fuel Problem
    I recently bought my first Tige and am new to the forum. I have a 2008 20V and last weekend started having an issue with the motor. It stalled out and didn't have power and eventually died. After a while it would start up and run. This usually didn't happen until I turned it off and parked for a little while. When I pushed up power to get on plane it would stall out and then after a few minutes it sounded like it worked out the air in the line. I found a brass fitting (with a check valve in it) coming off the fuel pump that was loose and when I tried to tighten it, it was already stripped so it couldn't get a good seal. I also checked the fuel filter and it looked clean. I have the Marine Power 5.7L, anyone know where I can find this fitting or the part number? Also, has anyone had this problem?
    Welcome to the site and congrats on your new boat. Post some pics of your boat.
    Post some pics of the part that you need to replace. You say that the fuel filter looked clean, do you know when it was last changed? Has the boat been sitting? If it has I would add some marine stabil.
