I have a 03 Merc 350 MAG MPI. Of the last several weeks I have had a cold start issue. It take about 15 to 20 minutes to start the engine. Once I get it started and warmed up it is fine the rest of the day. Even after sitting for a while. Mechanic suggested Plugs since mine were old so I rplaced. Then the Boost Pump.(Fule)
Today I was having the same starting issue. I noticed my Starter was smoking. You could here the cylinoid burning on the inside. I replaced the starter and went to start the boat. The engine never turned over I just lost all power to the dash. I still have 12.5 volts to the started and the auto bilge still works. I checked the breaker on the engine. not sure what to look at. Anyone have any clues?
