I believe my alternator is bad and so I took it to O'Rielly's. The machine they hook it up to test needs a part #. This is a 2007 24VE 340HP Marine Power. Is it the same as a 5.7L Vortex? It is already pulled out of boat and would like to test and rebuild if needed. Suggestions?
Marine power alternator
Its a 90A alt. IF it is built using a Delco housing, a part number may be stamped into one of the ears.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Well, if OReillys says the alt test good, then let us know what your root problem is. Im guessing your Ve has the Tige EIDB dual battery setup?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
