07 24v drives moter stays running but throttle shuts down and boat starts beeping
    Not losing fuel pressure if I put the throttle in nuetral and
    Take off its back to normal drive for a minute and does the same
    Thing any ideas what may be wrong has to two different place they can't figure it
    Out nobody around Tulsa has the software to read the codes
    Sounds like a code 81 , related to the pps , either out of adjustment or going bad.
      What is a pps?
        Its a sensor on the throttle handle that request the ecm to accelerate the engine, when it fails it puts the engine in limp mode which is ildle only, there are several threads on here of this issue, you should be able to find prior info, or somebody will chime in.
          dom is probably correct. Have you tried H2O in Stillwater? They are a local dealer. Mine wold do the same similar thing and turned out to be some loose fuses and wire connections.
          Wake Up or Stay On Shore!
