Had a starter problem with a loose wire and the wire must have shorted something and blew a fuse. Where is the fuse located to allow the key to start the engine or turn it backwards to auxiliary. The bilge, blower, tower lights, deck lights all are working.
Key does not start Ignition or turn on LCD display
On top of the engine or mounted to the fire wall behind the battery you might find a circuit breaker that has tripped. Push the button or lever back in and you should be set.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
