Ok so I have this phantom problem with my motor just cutting out with no patern other than while crusing at almost wot or surfing. Runs fine but will just randomly die. But always fires right back up. Anyone think fuel pressure regulator could be the culprit? Only thing left I haven't tuned up is cap and rotor but they looked fine so I didn't yet. Ideas??
fuel pressure regulator problem?
You can put a fuel pressure tester on the rail to determine if the regulator is bad. Fuel pressure should pop up above 25psi when you turn the key to on and then SLOWLY (within 5 minutes) go back to below 10psi. When running the pressure should be around 32psi +- 4 psi. If the pressure goes higher, like climbs and doesn't stop, then the regulator is bad. Problem is, it's located on the fuel pump which is located on the starboard side engine forward motor mount in that stupid Mercruiser cool fuel plastic box. You will need the regulator kit AND the brass adapter fitting that screws in to the front of the regulator, you will not be able to remove it from the unit without breaking it.
Also, tune up : ignition sensor, coil? I've had a rash of ignition coils go out lately and Mercruiser is backordered on them until July 30th, the sierra ones have had issues so I'm just waiting for the factory ones.Fixing everyone elses boat just so I can use mine...
Originally posted by boatwakes View PostYou can put a fuel pressure tester on the rail to determine if the regulator is bad. Fuel pressure should pop up above 25psi when you turn the key to on and then SLOWLY (within 5 minutes) go back to below 10psi. When running the pressure should be around 32psi +- 4 psi. If the pressure goes higher, like climbs and doesn't stop, then the regulator is bad. Problem is, it's located on the fuel pump which is located on the starboard side engine forward motor mount in that stupid Mercruiser cool fuel plastic box. You will need the regulator kit AND the brass adapter fitting that screws in to the front of the regulator, you will not be able to remove it from the unit without breaking it.
Ignition sensor is under the rotor in the distributor and if it's original will only have two wires, white with green and white with red. The new units have a ground wire included as well. The pressure tester connects directly to the rail at the schrader valve, yes.Fixing everyone elses boat just so I can use mine...
