My Taps is stuck in wakeboard mode. When I press up on the switch the motor sounds normal however when I press down in sounds very quiet and slow. It appears to be full of fluid. From reading other threads I assume it is either the pump, a clogged line, or a bad hydraulic deal in the back. Can anyone tell me how to narrow this down. Thanks
