Heater
    Heater
    Im am in the process of purchasing a '04 22v. I was going to place an order but the dealer has one very close to what I want on the showroom floor. The one option that the dealer's boat is missing is a heater. Is the heater a factory only option -or- can one be dealer installed?
    yes
    Freude am Fahren.
      Thet's yes as in it can be a factory option and yes the dealer can install one fairly easily.
        Thanks for the reply. I'll go back to the dealer and inquire. The sales person indicated that it was a factory item only.
          i bet he (your dealer) meant it's a factory item they would have to order from the factory, and install at the shop.
            is the heater a heater in the boat? or a shower type heater? if it's a shower type heater you can install one yourself for CHEAP!! go to www.diy.com. Just some info
            Dom
            Originally posted by G-MONEY
              Its a heater in the boat. Typically it has 3 or 4 vents that blow heated air into the main cabin. A buddy of mine has one in his Mastercraft X10. It sure make's it nice on those cold morings when your racing accross the water to your favorate boarding/skiing spot.
                The heater can be installed at your local dealer. It operates alot like the heater in your car/truck, it uses the warm water from the cooling system. The standard heater comes with 2 vents, 1 under the helm, 1 for the passengers. Money well spent on those cold moring runs.
                Greg Denton
                  What is the cost at the dealer? i.e. Tige Watersports in Corona
                    Call John at 909/737-9801 he can give you an estimate.
                    Greg Denton
