Fellow Tige Owners,
one of the Vault Bearing Buddies has fallen off at some point over last summer. In speaking with the manufacturer the trailer is still under warranty so they sent me the parts to install a new Vault Bearing.
My first question is do i need to take the hub apart and re-pack the bearings etc?
Also the instructions that the manufacturer sent over includes a zerk fitting to grease everything but my axle doesnt include threads for the zerk. the manufacturer responded- "Only about ½ of the spindles are welded, the others are just hand packed. The zerk was sent just in case yours was drilled. Keep it or toss it."
as the instructions show your supposed to be able to apply a zerk fitting to the front of the axle but mine doesnt have any threads. should i just follow the instructions other then adding more grease through zerk?
any thoughts would be greatly appreciated as i am very confused and dont want this thing to fall apart on the road.
