I need some advise from you guys. I have a 2007 24ve. On my last outing of the year I hit something and bent the prop. I am sure that just the prop was bent and not the shaft. I was goung slow and out of gear.
My question is... Do I take it some where to have it fixed or just buy a new one? Also if I was to buy a new one should I change to something else in size? Any recommendations?
I surf with the boat and the RPM range at that speed seems to load a little but we board at 22mph. When we surf I do add about 1000lbs of ballast.
