I had been having issues with water getting into the engine compartment last summer and determined that the hose was leaking at the fresh water intake at the transmission cooler. When I tried to tighten the hose clamp down I discovered that I must have over tightened it because the cooler flange was crimped. I have tried to uncrimp it using a needle nose pliers but it still leaks a little. Anyone have any other suggestions other than total replacement?
Thanks.
Thanks.
