pull out heaters?
    pull out heaters?
    Has anybody installed the pull out heaters on there own? My boat does not have them and I want to put them in this winter. Any advice on which company makes the best and where to get them. Also curious on what location to install in the boat?
    The default answer is heater craft. They have many different options on how many hoses and if you DIY you can put them anywhere you want. I have usually seen them by the feet of the observer seat and on the side of the walk-thru area on the drivers side. The core is usually installed under the helm but you might be able to put it on the passenger side too.
