The alarm on my 04 20' Tige vSwitch starting beeping about 2 weeks ago for no apparent reason. The oil pressure and level is fine, the motor is not overheating as the temperature is normal and the motor runs fine. Tige said it could be a knock sensor. My primary battery did need charging but when i switched to my fully charged back up it kept beeping. Does anyone have any ideas on why it would be beeping at me? I changed the water pump impeller 2 summers ago and have maybe put 60 hours on it. Thanks for any help!
Alarm Question
