I checked the oil level and all is fine there. Once or twice out when I am driving at higher speeds and then throttle down to slow down significantly my alarm goes off and I see my oil pressure gauge go down to below 5 which is what triggers the alarm. I turn off the engine and then restart it and everything is fine or if I just idle for 30 seconds with the engine running the pressure goes up again and the alarm stops. Any ideas of what is going on? Thank you.
Alarm Sounds when throttle down
Oil is sloshing to the front of the pan and away from the pickup while decelerating. If oil is low, the pick up tube can not pump it. If it is over full, it can froth and try to pump bubbles . Too light weight and centrifugal force pulls it away from the pick up tube. You might try adding some amsoil oil stabilizer to make it thicker and more sticky.
Originally posted by moved2ski View PostOil is sloshing to the front of the pan and away from the pickup while decelerating. If oil is low, the pick up tube can not pump it. If it is over full, it can froth and try to pump bubbles . Too light weight and centrifugal force pulls it away from the pick up tube. You might try adding some amsoil oil stabilizer to make it thicker and more sticky.
Either way, I would do an oil change just to confirm the amount of oil in the pan is correct. Also, an over full crankcase can actually cause foaming. The churned up oil will create a false low pressure because the senders cant rear air bubbles.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
