I just got back from a nice week at the lake and we had a small issue a few times.
The problem was that boat would not start in neutral unless I moved the throttle back and forth. (This only happened a couple of times) so I figured would ask if anybody has adjusted there start switch before I start taking everything apart.
Is the adjustment located on the transmission or the throttle?
I have a 2004 SwitchV with a Marin Power 5.7.
The transmission is the same color as the engine and I have the blue v-drive. (Sorry I can give you more detail, but I am not home)
Thanks for any information
David
David
