Depth gauge problem!!!!!
    On my 2008 Tige rz4 the depth guage reads all over the place. One time it'll
    Read 12 feet,2 feet, 900 feet where is the depth sensor? What should I do
    Do you have the puck type transducer? If so, it probably came unglued from the inside of the hull and is not making good contact. Has happened to mine. Just rough up the place to glue it and use good quality epoxy to glue it down. Cleanliness is the key to good adhesion.
      I don't know what kind I have if I have the puck style where would
      It be?
