loose tower on 09 rz4
    when you push it towards the bow theres a 1/4" gap at the bottom backside where it seals to the top of the boat and the sealant is starting to crumble and fall out. ideas on how to access this for tightening and has anyone else had this problem with there alpha z?
    I have a 24Ve of the same year, and other than the bow there is a lot of similarity between the two hulls. I just discovered that there are two access holes for the tower, supposedly to permit the tower bolts to be tightened. I haven't confirmed this but thought I'd pass it on in case it helps.
    They are located above the cup holders in the passenger area behind the driver's seat. Those cupholders are recessed into the gunwale of the boat. The plastic above the cupholders has a ~4 inch circle roughly cut into it. Here's a photo of one side of mine:
    Hope this helps!
