Has anyone had the problem of the walk through windshield of falling through the opening? The left side of the walk through only catches a small amount. When we hit rough water or large wakes the windshield must spread and the walk through falls through. I have to then spread the left & right windshields to get the walk through back in place. We have a 1994 2002fslm.
Windshield problem
Found it. Hope it helps?
http://www.tigeowners.com/forum/show...windshield+gapMike Allen, Tigé owner since 1997
not trying to rob the thread but i have alittle probolem with my windshield as well. my slip is some what shallow so i have to use straps for a lif. i always open my walk thru when i lift the boat and agter about 6 months the boat flexes bad enough to where my winshield wond close?????? any suggeestions?
Originally posted by AdaminMN View PostSomething TeamAllen forgot to mention...Since your new to the site, you need to post a pitucre of your boat. It's just a formality.
Originally posted by isp5190 View PostThanks, I thought I may have to reset the windshield. Is that what you did? If so any hints.
Steve
Originally posted by kana12 View Postnot trying to rob the thread but i have alittle probolem with my windshield as well. my slip is some what shallow so i have to use straps for a lif. i always open my walk thru when i lift the boat and agter about 6 months the boat flexes bad enough to where my winshield wond close?????? any suggeestions?Mike Allen, Tigé owner since 1997
There are plastic slides you will see with the window open. Make sure those are pushed ALL the way DOWN since they apply pressure to the pins and keep the window from popping out. With age they get lose and can pop up. they're supposed to lock in place with friction and a little catch but they aren't wonderfully effective once they get a lil worn out. I tapped mine a little bit w/ a small hammer and then put JUST A DOT of glue on them. It has held so far...but I haven't tried to remove it yet so I can't say if the glue was a great idea or a terrible mstake. lolOther than that, Mrs. Lincoln, how was the play?
