Hull repair/touchup
    Hull repair/touchup
    Need some advice on what to do about a hull chip repair and what, if any, are some preventative measures to take. I know there is some kind of keel gaurd that you can put near the front, but the chips are near the bottom. See photos.
    you can use an epoxy resin and add color. Getting the color correct is the challenge. Good Luck.
    Dale
    2000 21i Tige
      Here are a couple threads with tips on gel repair. One was more extensive, one less so. Searching for "gel repair" will bring up a lot more threads that you may find useful.
      http://www.tigeowners.com/forum/show...ght=gel+repair
